i have a 15kva MP2, ac coupled with 8 x PP4851managed batteries. Over the last 2 days the inverter has shut down and restarted (276 low voltage), Once at night and once during the day. There is no low voltage, does this indicate a BMS issue?
Good afternoon,
Indeed, looks like it, your discharge limit went straight down…
Is it possible to make another unit master, maybe that helps?
Regards, Jeroen.
The low voltage from the inverter may have been that the battery temporarily switched off its output, but then recovers.
That is definitely triggered by the battery (0A DCL), the real question is why?
What was the pack voltage?
I see an hour or two afterwards the battery requests quite a high CCL much higher than the previous request.
