I have a CALPEDA lifting station with two pumps operating in alternating mode. They start one after the other when the water in the tank reaches a certain level. There is a relay on each pump, so I have four dry contacts giving me the times T1, T2, T3 and T4, corresponding respectively to the start and stop of pump 1, followed by the start and stop of pump 2. I would like to retrieve a timestamped file of these successive starts and stops so I can measure when the tank starts filling and the pumping rate of each pump.
As I have a MULTIPLUS, I would like to use it to monitor my UPS system (two batteries charged by the MultiPlus), which allows me to switch over to battery power if the mains supply fails and power the lifting station from the batteries.
I know nothing about the VECTRON data transmission protocol, so I would appreciate some help connecting the Cerbo GX to the MultiPlus and the pump control panel, and understanding how the timestamped file can be read, as well as the various MultiPlus and battery parameters.
Many thanks for your help.
