Some help please - Re: beta version numbers
I need to modify SetupHelper to accommodate the new numbering system: “~” to “-beta”.
Will the string “-beta” always be used or will there be shortcuts e.g., “v3.90b56” or v3.90beta47
Are there any other strings I need to handle? for example something for alpha, test or development releases?
Because the currentSetupHelper / PackageManager code is not recognizing “-beta”, those version numbers will unfortunately be interpreted as release versions when comparing versions to see which is newer or within the acceptable version range for a package. I don’t think anything bad will happen yet except that the beta version portion of the number will be ignored so v3.90-beta14 and v3.90-beta20 will compare as an exact match, which of course they are not. If package versions retain the ~ as a beta indicator for the moment then everything should work OK I think.
