Modifying an existing camper with very little space
Campervan instal under a bench seat. Not very much room at all, integrated into the existing Sargent Ec176 and wiring
Cerbo GX, Multiplus II 12v 3Kva, Smartshunt, Orion XS, Smartsolar 100/50 + 100/30, 12v fused distribution, Ac2 powering the EC176, sockets from AC1, active venting of enclosure (linked to multiplus ii relay triggered by internal fan activation), connected to 2x 300ah lithium batteries in parallel, 600wh of solar on the roof, 360wh portable solar
The large Anderson connector connects an additional bank of 2x 200ah lithium batteries when extra capacity is needed (fused, switched so no load when connecting/disconnecting)
Also made temperature sensors for the Orion XS and Smartsolar 100/50 to trigger active fan cooling on those. Additional ve.direct ports provided by DuPPa usb to ve.direct hub. The two switches by the side of the Cerbo give the option to enable Ac2 out when no mains available (if needed) and the second is to turn off the internal fan (fan assistant) at night.
Keen eyes will notice the Multiplus ii LEDs have been relocated to the top side (which I did when Victron sent a replacement main board and fan that I swapped out myself under warranty)
Roof rack, awning, ladders, induction hob, microwave also added. WiFi, Ethernet switch, and a raspberry Pi running home assistant fully integrated with the Victron MQTT server.
