Mixing 4a and 4c solar panels
Hi
Can I mix 4a solar panels with 4c solar panels now that 4a panels are no longer available.
Brian
Strings of panels can be combined in parallel if their open circuit voltages are within 5% of each other.
You can also combine panels in series if their Isc and Imppt values also match within 5%.
so check the label on the back of the module for the Voc and Isc ratings.
