Minimum value for "max charge current" setting?
I would like to put together a solution for charging 12v batteries that range from 10Ah to 50Ah. I would like something that can safely charge the 10Ah batteries at 0.5C (or so) while still being able to utilize higher current for larger batteries.
I see that the Victron charge controllers (I’m looking at the SmartSolar 100/30) have a “maximum charge current” setting, but there’s no information on whether there are any limits to how small this value can be.
Can I set the maximum charge current as low as 5A?
Thanks!
Typically the lowest current setting is about 1A. Depends a bit on the product.
Load the VictronConnect app to your phone, there is a demo product option where you can load the product and see what the settings options are by trying it out.
Thanks, that was super helpful! I didn’t realize the app had a demo mode like that.
