MicroSD not detected on Cerbo-GX
I’m experiencing troubles with the storage of the cerbo. My microsd card is not detected by the cerbo. It’s a 16gb sdhc formated to fat32. It’s the first time I use the sd card fonction because I had no use for it until now, did I do something wrong?
PS: cerbo is running on V3.50 (GUI v2) and I know RTFM ^^
You’re running a beta version, so rather revert to prod 3.4x official release and GUI v1 and retest.
Q&A can’t help with betas, and there are known issues.
If you verify this is a beta only issue after testing, report it on the right beta category, after reading the how to post topic in the beta parent category.
Thanks
Hi Nick,
Thank you for your answer, I thought this could be linked to the beta version but I did not find anything about that…
I’ll report it if I that’s a beta related problem.
Please test it first with GUI v1, to see if it is a V2 issue, and ideally 3.4x which eliminates the beta and any local issues.
This is the preferred way of troubleshooting faults.
On V2 GUI my SD is working fine.
Hi @nickdb, turns out that was not the OS… it seems to be coming from the microsd itself for some reason. I bought 10 sd card, and this one doen’t work on cerbo, which is odd because it worked just fine on my computer.
I can’t figure that one out.
Thanks for helping me anyway.
