I have an ESS installation with 3 MultiPlus II 6k5 units in a three-phase configuration, a Fronius Symo AC-coupled, an MPPT 250/100 DC-coupled, an Ekrano GX and 32 kWh of batteries.
When the sun is shining brightly and the grid voltage rises because many homes on my street have PV systems, grid feed-in stops in accordance with the local settings (Belgium). Every time feed-in is interrupted, there is a brief power cut on the AC OUT side, which causes some equipment (printer, NAS, etc.) to restart.
Have you tried comparing the SOC and/or load graphs in VRM when the AC Out switches off? Perhaps some settings are wrong and the MultiPluses are switching off the AC Out as a precaution …
What are the SOC and/or load levels at that time? How is the Fronius connected?
Jonas s posted a video here on 17 September of his three-phase ESS with AC PV on the AC out. The switchover behaviour during a grid failure is odd for Jonas when the grid fails while the system is producing at full capacity. But this only happens when the battery is full and the AC PV is running flat out.
Have you ever simulated a grid failure under different conditions?
