MB31 cells with single or double terminals?
It’s the 200A Seplos BMS. It connects straight to the Cerbo GX. The battery usually cycles at least once per day. I mainly just export back to the grid during peak rates (4pm to 7pm).
The difference between the lowest and highest cell voltage is currently 0.002V. I think that might be just as much the quality of the MB31’s than the BMS/Balancer though.
I’ve recently added this GitHub - syssi/esphome-seplos-bms: ESPHome component to monitor a Seplos Battery Management System (Seplos-BMS) via UART, RS485 or BLE · GitHub . This connects to one of the other RS485 ports that would normally be used for linking multiple batteries together. It doesn’t affect the connection to the Cerbo and provides very detailed battery stats on Home Assistant.
Is that when balancing at 3.45v >? Otherwise it doesn’t show anything on how balanced the cells are, LFP has a very flat voltage curve between the high and low knees.
This topic has strayed a bit from our purpose, it is better discussed on a community that focuses on battery making or general DIY builds.
Nobody mentions the technical pros and cons: Double Studs have a higher mechanical load-bearing capacity and are more resistant to vibration. In a boat or camper van, go for Double Studs; in a house, they offer no advantage at all, so you’re better off using single studs. I saw a video from EVE itself explaining this, but I can’t find it now. Good luck building your battery!
