MB31 cells with single or double terminals?
I’m going to use the MB31 cells, but they are available in single- and dual-stud versions. I prefer the dual-stud version (2x6mm terminal), but these are very hard to find, especially if you want high quality (which I do).
Does anyone have any experience with these, with either the single or the dual terminal?
The dual version seems more robust and reliable, but the single version is readily available.
With a double setup, make sure to use flexible busbars.
There have been YouTube videos in the past showing that double setups can cause problems when there’s even a (small) height difference between the batteries.
More importantly, what BMS and enclosure are you going to use?
I have 2 × single-stud cells, 32 kWh in total (grade A), and a JKBMS in an Eelbattery enclosure. With the right software, you can read each cell.
For a house, using double nuts makes no sense at all. Perhaps for a motorhome or some sort of golf cart, or similar, but if they’re going to be stationary at a house, buying them with double nuts offers no benefit.
I’m indeed aware that there have been incidents where the small aluminium block with two holes welded onto the cell broke off. Possibly because it was tightened too much, or for the reason you mentioned. I use flexible busbars and Class 6 cabling anyway, and install them with plenty of slack so they can’t be strained.
I had single stud cells, in some of the provided busbars I had to drill new holes, be sure to tighten the nut manualy by hand, then torque them accordingly.
You know Pylontech has now 16 kwh batteries for only euro 1970.-?.. I wonder wich cells are inside?
The tricky thing about battery cells is that the terminals are made of aluminium, which is vulnerable, and must absolutely not come into contact with copper or galvanised iron. You need to use aluminium busbars, high-quality, heavily tinned cable lugs, and stainless steel bolts, nuts and washers, because of galvanic corrosion of the cell terminals.
I’ve already started the project, and ready-made batteries are no longer an option for me. There are several brands offering 16 kWh modules for around €2,000. The problem is that you don’t know what’s inside, and the warranty terms are laughable. If they guarantee 8,000 cycles with a remaining capacity of 70%, i.e. an average of 85%, then you can calculate the throughput: 8,000 cycles x 16 kWh x 85% = 108,800 kWh. If you read the warranty terms, they may only guarantee a quarter of that, and you also have to provide a digital log so they can see that the system hasn’t been used outside its specifications.
Whether you build it yourself or buy one, you just have to wait and see how the system holds up.
I’m going for the single stud; the double one is almost impossible to find, and I don’t want a collection of bits and pieces.
Tin has much higher resistance then copper, basically you don’t want to use it​:thinking:
Long ago, analog telefone centre’s did have metal cabinets bolted together with brass bolts and nuts, I don’t thing you have galvanic corrosion with brass.nuts on aluminium in a dry and warm environment.
Hardly anyone uses Aluminium for LFP Busbars anymore as they suffer poor contact and oxidation. Just get yourself tinned flexible copper busbars and don’t worry. I have a few DIY batteries with single hole studs, they don’t overheat even at a constant 0.35C, my current DIY boxes coming from EEL in China have the dual studs, there are many sellers on Alibaba with the dual hole terminals, some have EU warehouses. But I see NKON are out of stock. I think some issues with them are they get snapped in shipping if not boxed properly, or re-sellers lasering their own studs poorly which can be torqued off, rather than buying the original, like EVE dual terminals ready laser welded as EEL do.
You’ll find the 8,000 cycles warranty to 70% or 6,000 to 80% SOH is from the data sheets of the cell manufacturers, and it’s normally 3.65v to 2.5v test at 0.5P / 0.5C so 100% capacity of the cell, not from the battery box manufacturers, this is a product of current LFP construction, so you’re unlikely to see much else.
But these copper busbars are tinned, I assume? The documentation from Klauke, for example, explicitly warns about this. There are even special cable lugs for connecting aluminium conductors to copper busbars, because otherwise galvanic corrosion occurs. This cable lug has a special material as a separator, but it’s intended for industrial use.
I’ve never actually handled these flexible busbars for batteries. I am familiar with laminated flexible copper busbars from companies such as Rittal. But these are heavy, metre-long busbars for switch cabinets, made up of, for example, 10 layers of 1 mm thick copper.
In my case, the current through the cell will be a maximum of around 0.25C.
The busbars in the Victron Lynx system are also made of tinned copper; that’s indeed also because it’s intended for marine use.
I would personally always get the double stud MB31’s. There’s plenty of cheap copies from China and, although not fool proof, the double stud is a little harder to copy.
What problem are you trying to solve? As I have only heard of issues with non standard aluminium busbars on battery terminals, whereas tinned copper flexible busbars are the preferred choice. If you are concerned, you can always apply some No-Ox-Id or similar: https://www.sanchem.com/electrical-contact-lubricant.html
I want to order the original EVE MB31 HSEV Grade A from Gobel via its EU branch. They have plenty of the single-stud versions in stock. I don’t know which busbar is supplied with it; I assumed it would be aluminium. But I have indeed heard about oxidation on the busbars before; I think it was Andy from the Off-Grid Garage (YT).
Looks like you’re using a Seplos active balancer (the circuit board above).
Seplos V3 BMS with an JK BMS Active Balancer
Gobel will supply the tinned copper flexible busbars normally like the ones in pau1phi11ips picture, but small things like that are always good to check before ordering, they will also supply other variants if you ask and they can find them, but I’d stick to the tinned copper flexible.
I bought some Gotion 340Ah cells from Gobel in 2023, they couldn’t supply the flexible bars as standard at the time as the cells were a larger size than standard LF280K, so they sent solid tinned busbars, which have been working fine but I stil mean to swap them out for flexible. It took 72 days to arrive after ordering from China, but I can’t use their EU warehouse as i’m in the UK, but if you can wait then they may have stock in China to ship, best to ask them for a quote.
Are you happy with the V3 BMS and the active balancer?
I know from a reliable source that some wholesalers specifically use the Seplos V3 BMS because of its reliability. They then pair it with a simple 2A active balancer (JK-B2A16S) from JK. The JK active BMS is deliberately not used because it has a higher failure rate. They were not yet willing to use the active Seplos BMS you use because there is not yet any reliability data for it.
Which one exactly do you use, 200A or 300A?
You’re right, I just read it on their website too!
NKON has been out of stock for ages. Gobel did have EU stock a few weeks ago and is a reliable supplier; they supply them with a capacity report, straight from EVE.
The double studs are definitely worth it; they install beautifully, and the contact resistance is simply much lower thanks to the much larger contact area.
So you’d already found them, then—nice. Gobel does indeed fit aluminium studs, just like NKON. Giving them a good clean with isopropanol and lightly abrading them with Scotch-Brite just before fitting the busbar makes a huge difference.
