I’m assembling a 48V System which include 2 Multiplus-II 48V 5000W. I’m using the lynx suit for my distribution (lynx class-t power in, lynx shunt and lynx distributor) 2 battery string will enter the power in.
For safety I wanted a way to shut off the system, adding a master switch, but looking at the current draw (over 400 amps according to victron fusing recomendation) I can’t find a master switch big enough. Before you ask, the Lynx BMS unit isn’t sold here in Quebec as it’s not approved (yeah i know…) so i’m trying to find a solution to support the 1000 possible amps of the lynx power bar. Any suggestion ? I thought perhaps it’s better to have a switch for each unit instead of one for the batteries. This gets more complicated since i have 2 battery string, if I close one of the two, nothing stops me from drawing the whole amperage from a single battery string, so they have to use the same master switch as I undertstand it. Any advice / suggestion ?
