I lost contact with my system at 7:45 this morning. A remote diagnosis via VRM wasn’t possible. First, take a deep breath … maybe it’s nothing serious. Then I popped home later to have a look …
The initial diagnosis was a blown blade fuse in the 48V section (primary side), which supplies a 48V-to-5V converter.
The 5V supply (normally) powers 2 USB hubs, a network bridge for reading the Pylontech, and a switch. Now there’s no power … so no network communication. After removing the faulty 5V converter, I disconnected the USB connections from the first USB hub … connection to the Cerbo (phew, no damage to the USB ports), 2 USB-to-RS485 converters (boiling hot and not a good sign … both faulty), a (faulty) IO Extender, a USB-to-VE.Direct converter (survived! ) and a connection to another USB hub with 3 USB-to-VE.Direct converters (all 3 faulty)
The network bridge and network switch survived!!!
So the result is a system without communication with 3 meters and the MPPTs …
After quickly getting hold of another USB-to-VE.Direct converter, I found the 3 MPPTs in Victron Direct one by one … Good sign
2 new USB-to-RS485 converters for the meters are arriving tomorrow … fingers crossed
Why am I writing this … Well … how can you prevent a disaster like this on the USB communications side with USB hubs … regardless of the power supply … Maybe a fuse on the secondary 5V side would have been enough … the primary side tripped at 1A … For now, I’m using a much-too-large 230V-to-5V Meanwell power supply from the spares box
I’m hoping it’s only the “communication converters” that got hit and that the 4 meters are still OK too … I’ll report back
So have a look at your systems and see if there are any power supplies that could cause this kind of trouble … This really shouldn’t happen.
PS … I’m very curious again to see how the translator handles this
The converter shown does look really well made, too.
You might want to add a fuse and thyristor overvoltage protection to units like that. If the voltage exceeds the limit, a thyristor fires, creating a short circuit and blowing the fuse (provided the converter can supply enough current).
Keyword: electronic fuse
There are loads of circuit designs out there, but ready-made units are mostly only available for 12, 24 and 48 V DC.
I’ve even extended a VE.direct-to-USB adapter with a 15 m (or was it 20 m?) USB extension cable before. There was a “lump” in the middle of the cable with electronics that refreshed the signal.
!!! Also, BEWARE of powered USB hubs if they are NOT absolutely necessary !!! … Regardless of whether they are powered by a DC-DC or AC-DC converter.
They absolutely must be galvanically isolated … I currently have my eye on the Meanwell SD-15C-05 … Of course, only for the switch and the network bridge. The USB-to-RS485 and USB-to-VE.Direct connections should be used without powered hubs.
Well, there’s no need to make it quite so dramatic.
But it can’t hurt to try a passive hub first.
I think it always depends on the number of devices too.
We have a system with two 4-port hubs, both fully occupied, and one of them is also connected via a 1.5m extension cable.
as a rule, I only use isolated converters for this. They do have a lower efficiency, but I can almost completely rule out the possibility of an overvoltage at the output, since in almost all conceivable fault cases, the converter stops supplying any voltage.
With a simple step-down converter, on the other hand, the input voltage can end up at the output in the worst case.
However, converters like these are also considerably more expensive; you can’t get them for a few quid. I do like to take advantage of special offers when they come up, though. Then you can sometimes get a converter for 20 euros that would normally cost over 200!
They don’t come with cables attached, but you can solder some on. With a bit of luck, you can sometimes find one like that for 5–10 euros, rated at 10–20 W.
I’ve had some sitting on the shelf for years before they finally came in handy! I just like to keep this sort of thing in stock in case I need it, and if I can order them for a fraction of the normal price, I’ll buy a few extra. It’s still better than paying five to ten times as much later!
After replacing the 3 USB-to-VE-Direct converters, all 3 MPPTs are reachable again … so they are isolated (as stated in the technical specifications)
After replacing the two USB-to-RS485 converters, the 4 meters are also reachable, and the ESS is receiving readings again for the grid, heating and 2 x PV … so they are at least sufficiently isolated between the power supply and the measurement side
So the converters have prevented something worse here …
the RS485 converters don’t transmit supply voltage, and the devices themselves don’t share a common ground potential, so nothing can happen. Even if they do share a common ground potential because the ground is connected or via an external connection, nothing can happen then either, and the VE.Direct converters are isolated!
only components that can be exposed to an excessive supply voltage will fail.
These we use (sometimes), MEAN WELL RSD-60, they last more than 60 years and have a huge overkill (2.5-12A models), isolate 4KV, a piek to piek ripple of 80mV, only 89% effective, but these stay stable under all conditions.
But for “home” applications, I suggest to use a Victron dc/dc converter with a 12V output, then use any 3 pin voltage regulator (30cents) to 5V (1A) and a simple 1000microF capacitor, with a 500MA fuse, to save electricity, or multiple in parallel, so 4 ic’s then 2A fuse…
I use Victron dc/dc to power my tv/sat/ter receivers and internet/Ethernet centres already 15 years and never failed.
Be aware to overpower the DC/DC inverter for twice the power (or more) you will use, to stay absolutely stable and never overload the DC/DC’s.
We’ve had a good dozen Meanwell RSD 30L and RSD 60L units in various output voltages running here for over five years without any problems. They’re not exactly cheap, though. Failures occur when the input capacitors on the 48 V side are undersized or missing altogether. Long DC cables have inductance, which generates significant voltage spikes when the current fluctuates. Victron seems to have learned that the hard way too with an older Cerbo GX series, whose units running on a 48 V supply died like flies and had to be replaced.
With Meanwell NLDD series constant-current converters, you can expect a failure if you don’t solder an electrolytic capacitor directly to the input. We use these extensively for LED lighting powered by 48 V DC, independently of the 50 Hz mains, and failures are pretty rare.
For an active USB hub with a 48 V supply, I can recommend the Exsys EX-1596HMVS. It’s not exactly a cheap USB 2.0 hub, but it comes in an enclosure that can be mounted in a control cabinet with or without a DIN rail. The (48 V) PC’s USB output isn’t burdened, and the switch gets its 48 V supply through a separate 2-pin connector. Inside, it uses a Texas Instruments TPS54360 voltage regulator, which can deliver up to 3.5 A across the six USB ports. We’ve had two of these running in our installations since 2022.
We use Mikrotik RB5009 routers here with a direct 48 V DC input. The PoE switches are D-Link DGS1100 units, which work perfectly well when connected directly to a 48 V battery instead of using the power adapter.
If you want to prevent severe overvoltage, you can do so with a fast-acting fuse in series, correctly rated, and a Zener diode with a small series resistor, or even better, a TVS diode between the fuse and ground. I don’t know whether suitable VDRs are available for just over 5 V.
If an overvoltage occurs, enough current will flow to blow the fuse.
PS: But something like this should really already be built into the DC-DC converter. If it isn’t, then in my view those things are junk. The ones I’ve come across so far all have output voltage monitoring, according to their descriptions.
But the cause could also have been a load on the 5 V side. That could have overloaded the converter, which then only allowed the voltage through. But the units should really have protection against that too.
Addition: A voltage spike on the 48 V side is also possible. Have you checked whether the unit is actually rated for your battery’s end-of-charge voltage? With 16S, it could be almost 60 V.
