Manipulate temp sensor on dc/dc?
Hello!
I have a Orion Tr 12 |24 -10 but my boat motor only has max 17A output from generator. 12|24-10 means >20A at 12V. So it doesn’t work and I am wondering if Orion is lowering the current above 40°C in software or is it the actual hardware just can’t keep it up? If software, I want to manipulate the temp sensor and trick it into a higher temp. Where is it located on the circuit board?
/Mange
