New to Victron
Searched forum…no results found
can someone tell me where the temperature probe goes on the battery? Is it the positive terminal or the negative terminal? It doesn’t clarify that in the book and the manuals don’t have anything cross referencing which terminal it goes on.
Bonjour, sur le lynx, c’est le même montage que sur les Multi / Quatro donc la sonde doit être sur le pole négatif. Bon courage pour l’installation …
Hello, on the Lynx, it’s the same setup as on the Multi/Quatro, so the sensor must be on the negative terminal. Good luck with the installation…
Thanks
