In VE.Configure I have the battery monitor enabled as per manual to allow shutdown based on SoC. This is set to 20%.
Is this % based on the calculation inside the MP or will it instead look at the provided value from the SmartShunt (which will be more accurate) to shutdown based on SoC?
FWIW, I have DVCC enabled on the Cerbo and the LiFePo4 battery has its own internal BMS which is not seen by the Cerbo. On the Cerbo the battery monitor is set to the SmartShunt.
