Low battery warning
Hi, first time here.
I have a Low Battery warning on my Multiplus. Can I safely switch to Charger Only mode? Is that the right thing to do?
Welcome on board :grinning:
if you are connected to an electrical network with ESS the best is to switch to “keep batteries charged” mode
Thanks - I have changed that setting. Hope it sorts itself out :slight_smile:
Thank you for your help
With pleasure, or it works very well, just remember to put it back to the previous position when you find it useful
