I have a Victron MultiPlus 48/2000/25-32 (PMP482200000).
The unit works correctly, but the fan becomes quite noticeable already at loads of around 400–500 W, mainly because of the low-speed fan humming/vibration.
The original fan installed in my unit is:
Jamicon JF1238B2HR-R
24 V DC, 0.32 A
I found Victron’s SPR00090 fan PWM converter retrofit board, which converts the fan control to approximately 40 kHz and is intended to reduce low-RPM fan noise on MultiPlus-II units.
Since my MultiPlus 48/2000 uses the same Jamicon fan found in some MultiPlus-II models, could you please confirm:
- Is the SPR00090 compatible with the MultiPlus 48/2000/25-32 (PMP482200000)?
- Does the fan-control circuit of this MultiPlus use the same type of low-frequency PWM signal as the MultiPlus-II?
- Would installing the SPR00090 be expected to reduce the low-speed humming/noise on this model?
- Is there any electrical or thermal reason why the SPR00090 should not be used with the MultiPlus 48/2000?
- Is there an official retrofit or alternative solution recommended by Victron for reducing fan noise on this particular model?
I would prefer to keep the original fan and cooling performance, and only improve the fan-control behaviour if possible.
Thank you in advance for your technical advice.
