WolfBarn
(Martin)
August 20, 2026, 5:07am
1
I have been asked to see if I can find out any info on this Mppt 250/100
1 what may have caused this Damage
2 Where is this Built states US is that correct
3 Is it a Genuine Victron Product & if so how would it arrive in au from Victron
Why does it NOT show Voltages
Your Help is Appreciated
On the genuine models there are some big inductors on the models about there.
I have seen models running really hot but never changed the moulding on the mppt like that.
To check authentic put the serial number into the support page.
https://www.victronenergy.com/support
WolfBarn
(Martin)
August 20, 2026, 5:55am
3
Thanks
I thought the cover on all were Aluminium
do you think its Genuine having LC US on it (never seen that in Aust) what voltage would it be ?
nickdb
(Nick)
August 20, 2026, 5:56am
4
Check the serial number on the support site.
You can also see high-res images on the product site:
Martin:
Aluminium
Yep. Hence i was wondering how it would soften like that. Even the placement is not right of the pots.
WolfBarn
(Martin)
August 20, 2026, 6:56am
6
Thanks for that Me Neither not in 20 years I will pass this on to the relivant people
WolfBarn
(Martin)
August 20, 2026, 7:10am
7
How do you tell What Voltage that is WHEN NOT MARKED or does it span 12-24-36-48v batteries remembering its an older MPPT250/100 Tr
MPPT VE.Can SmartSolar chargers only on Victron now no older MPPT250/100 Tr’s
nickdb
(Nick)
August 20, 2026, 8:04am
8
If it has been configured before, then you will need to connect to it via the VC app to see what it has been set to do.
WolfBarn
(Martin)
August 20, 2026, 9:04am
9
Hi Nick
No I don’t have it but AFAIK you can’t configure VC app without DC Battery connected to the MPPT so what to do if Not Known ?
nickdb
(Nick)
August 20, 2026, 9:15am
10
If it’s powered by PV you can access it as well. Connecting it to a battery is fine, just isolate any solar first.
