Hello all, I cannot log-in on local network to my new version (Mk3) Cerbo GX as the password (which I have not set) is not recognised. I have tried all of the standard default password variations with no luck. I can access via VRM remotely with no problem, any ideas? I have not ever had this problem with earlier Cerbo’s
Did you configure it first with the victron connect app?
Thanks for the speedy response Nick. A good question which I don’t recall as I set this up some months ago. But I don’t believe that I have ever had to “configure” a Cerbo before - they are pretty much plug n play.
It always pays to read the manual. Use bluetooth via the app for initial setup, then take it from there.
Haha, yes, wish I could but I can’t log-in as it’s not accepting any password including on bluetooth.
The unique BT pin is written on the label that shipped with the device.
It shouldn’t ask for a password with a local login from the app.
Yes apparently so but I cannot find it on any of the stick-on labels that it came with. I read that the P/W is on a label on the back of the unit (I did not put it there) but as it’s in service and screwed to a wall I am reluctant to take it off on spec.
What do you mean by local network? If Wi-Fi doesn’t work because the password is missing, it should still work over LAN.
Thank you Hannus, it works over LAN and is connected to VRM but I would like to see it on local wifi or bluetooth like I can with my other Cerbo installations. I think I will have to take it off the wall in search of the password. Thanks for your time guys.
No need to remove it. The sticker is on the lower side, opposite the connections.
(trunking might be in the way, else check the box it came in, if you still have it, stickers are in the accessory bag).
I will give this a go when I’m next on site, but I have a feeling I have already tried this.
I do have some spare stickers but I sure can’t see any P/W or PIN on them, unless I’m going blind in my old age! (Which is quite possible) ![]()
Lol, thanks for the big print! I’ll have another look next week when back on site. Cheers.
When you access it, any passwords on the console itself can be configured via the security profile.
You may need to go to security and set a password? I believe fw updating resets it.
I don’t quite understand your problem. I can easily log in to the console in my browser using the Cerbo’s IP address. If VRM works, this should work too. It works for me with both the LAN IP and the WLAN IP. It doesn’t ask for a password.
There were changes to the software some time ago.
Settings → General → Access and security → Local network security profile
On a new GX device, access to the remote console is protected by a password (Bluetooth PIN).
How new? My Cerbo is two years old.
