Load shed with GX device
Are there battery disconnect devices that can be controlled by Victron protocols? LAN, VE.Direct, etc.
You could use the relays in the GX and a DC contactor to Open/Close the circuit.
Are you disconnecting DC loads or the battery itself?
Would like to disconnect the main battery. I have a bus system. Maybe provide only enough power to keep the GX and a few essential relays online.
Would like to have a 3 stage load shed. As SOC drop to specific levels, shed various loads (Critical, essential, non-essential).
Thanks, exploring Shelly devices, opto isolators, SmartSwitch DC4, and others.
Just remember an inverter should be used with a battery. But it possible to load shed using relays
