Hi everyone,
I’m about to switch from an off-grid system to a Victron-based setup. My current inverter allows me to protect my GEL batteries by limiting high discharge rates, which has worked well so far. In a couple of weeks I’ll be installing the Victron system, and I want to be sure I can achieve the same kind of battery protection.
Here is the hardware I will be using:
- MultiPlus-II 48V 5 kVA
- Cerbo GX
- Two SmartSolar MPPT charge controllers
- SmartShunt
- GEL batteries, still in good condition (and I don’t want to replace them yet)
I’m planning to use ESS mode, and my goal is to configure the system as follows:
- Limit the discharge from the GEL batteries to a maximum of 1000 W, in order to preserve their lifespan.
- Allow full use of solar energy from the MPPTs to power loads.
- If solar production is insufficient, the system should draw the difference from the grid (AC-in), not from the batteries beyond the defined limit.
I’ve read about the “Limit inverter power” setting, but I have some doubts before using it:
- According to the documentation, it does not take into account the power coming from the MPPTs.
- It only applies when AC-in is present.
I’m also aware of the “Limit discharge current” option, but it seems this only works with lithium batteries with BMS, and is not available for GEL batteries.
So my question is:
Is there a way to configure Victron to protect GEL batteries from discharging above 1000 W, while still allowing solar to power loads and using AC-in as a backup if needed?
Or perhaps some combination of settings (via ESS or GX) that can enforce this logic?
Thanks in advance for any technical guidance or shared experience.
