Hello everyone
I could use your help, as I’m unfortunately not very familiar with the system.
My system can operate off-grid; it only draws power from the grid when the SOC reaches 15%.
3x MultiPlus 5000
40KWH Pyts battery packs
4x MPPT 250/85 Tr VE.can
Cerbo GX
- As I occasionally have load peaks above 5 kW, I’d like to configure peak shaving. If I understand correctly, 4 kW would then come from the Multi and the rest directly from the grid, wouldn’t it?
2. I have set the grid meter to External, but which Assistant do I need to install to configure the system’s AC import current limit?
Thanks in advance
Regards, Bernhard
