Konfiguration Inverter
Hi everyone, I have a question about configuring a Phoenix Inverter 12/1200. I’ve set it to shut down automatically when the battery voltage reaches 12 V (lead-acid batteries). It does shut down as expected, but when I check the battery voltage in the app afterwards, both the charge controller (SmartSolar MPPT) and the inverter show 12.4 V. So it looks like the system isn’t making full use of the batteries’ capacity. Or could there be such a large voltage drop when the fridge compressor kicks in? It’s not a huge problem, but it would be nice if the system could use more of the batteries’ capacity. We use it to run a fridge in the Caribbean. Thanks!
Good evening,
As soon as you take a load off the battery then the voltage goes up again.
A fridge with A+++ uses a compressor of 100-300W only (pending the size), and does that to your battery.
That’s what you see, I don’t know your make and type of battery, but “normally” you can set that low cut off at 11.4V.
But, when you do that day after day, your battery will not last for long, so, I advice to buy a way way bigger battery as you have now, specially for a fridge…
Tell me the wattage and brand of the fridge and the AH and brand of your battery and I can advice more precise.
Regards, Jeroen.
Thanks, Jeroen!
That was my suspicion too: that the battery voltage drops under load. You know how it is with a car. Although 0.4 V seemed like quite a lot to me for just 7 or 8 A. I know better now, thanks to you. It may also be because only two of our batteries are new (2 years old); we were given the other two after the 2024 hurricane that flattened Carriacou completely. They were a donation from Martinique and had been used. It probably isn’t worth dismantling the system, at least not financially. The parts here are incredibly expensive. Lowering the cut-off voltage won’t help either. As you wrote, it would ruin the batteries. At least we’re now a little more self-sufficient, even as things stand. We’ve already had two periods when there was limited power from the grid—or none at all—for months: a fire at the power station, and then the hurricane two years ago. And life here isn’t particularly comfortable without a fridge.
Best wishes,
Burkhard
