No solar yield with Shelly as a PV meter
Hello
Since updating VenusOs from 3.79 to 3.80/3.81
The VRM portal shows that I’m getting power from the inverter, but no solar yield is shown in the system overview.
Has anyone else had this problem, or am I the first?
Regards, Jürgen
How did you integrate the Shelly?
Added via the Shelly integration and assigned the function “PV inverter” in the device list.
Use a shelly but via node red
It is individual feed because I build before they released the version where you send multiple messages. Used a Http request and a MPPT to the same shelly as I like playing. Not tried with the new shelly integration but this has worked for over a year
Dave
Like this, then?
Then it should work out of the box
I used to do that with the Node Red script too. If the Shelly is detected, native support makes things easier.
I did it like this, but the solar yield isn’t being saved.
I think there’s a bug in the newer versions where saving Shelly data doesn’t work, or something isn’t right with channel 1.
OK, I haven’t tried it with a 3 EM yet, but it should work the same way.
But does it work with 3.7x?
Yes, it worked without any problems. It stopped working after I installed the update.
In the first post, I’ve included a picture of the history from before and after the update.
Hi @Jonny537 this might be the same as in this topic.
Thanks so much for the tip. Back then, I had to reverse it to get it working.
And now it’s working again :heart::heart:
