JK-B2A8S20P CAN issues with Plink board
I have 4 DIY LIFEpo batties 4S i build with JK BMS. I added the new Plink boards so i could parellel the comms of these batties and connect to my Cerbo GX. when i installed the serial Batt driver the gx does detect the can bms. but dont show any info. only the battery voltage. The can logs show the bms is detected as Lljdb and not JK. what??? See log below. anyone know whats wrong here. BMS firwmare Ver. 19.17
CAN protocal is 4. victron canbus.
INFO:SerialBattery:Starting dbus-serialbattery
INFO:SerialBattery:Venus OS v3.70 (large) running on Raspberry Pi 3 Model B Rev 1.2
INFO:SerialBattery:Detected CAN Bus bitrate: 500 kbps
INFO:SerialBattery:-- Testing BMS: 1 of 3 rounds
INFO:SerialBattery: Testing Daly_Can
INFO:SerialBattery: |- No battery recognized
INFO:SerialBattery: Testing Jkbms_Can
INFO:SerialBattery: Testing LltJbd_Can
INFO:SerialBattery:-- Connection established to LltJbd_Can
INFO:SerialBattery:Successful battery connection at can0 and this address None
INFO:SerialBattery:Reconnected to previously identified battery with DeviceInstance: 2
INFO:SerialBattery:Use DeviceInstance: 2
INFO:SerialBattery:Use dbus ServiceName: com.victronenergy.battery.can0
Traceback (most recent call last):
weird i got it to work but i had to switch the CAN protocal to 0 JK BMS CAN.
Connection established to Jkbms_Can
INFO:SerialBattery:Reconnected to previously identified battery with DeviceInstance: 5
ERROR:root:Failed to add setting /Settings/Devices/serialbattery_CAN0__0X01/MaxVoltageStartTime, error -5
INFO:SerialBattery:Use DeviceInstance: 5
INFO:SerialBattery:Polling interval: 1.000 s
INFO:SerialBattery:Battery JKBMS CAN V2 connected to dbus from can0
INFO:SerialBattery:========== Settings ==========
INFO:SerialBattery:> Connection voltage: 14.248 V | Current: 0.0 A | SoC: 100%
INFO:SerialBattery:> Cell count: 4 | Cells populated: 4
INFO:SerialBattery:> BLOCK ON DISCONNECT: False
INFO:SerialBattery:> |- BLOCK ON DISCONNECT TIMEOUT MINUTES: 30
INFO:SerialBattery:> |- BLOCK ON DISCONNECT VOLTAGE MIN: 3.225 V
INFO:SerialBattery:> |- BLOCK ON DISCONNECT VOLTAGE MAX: 3.375 V
INFO:SerialBattery:> CHARGE MODE: Linear
INFO:SerialBattery:> MIN CELL VOLTAGE: 2.900 V | MAX CELL VOLTAGE: 3.450 V
INFO:SerialBattery:> FLOAT CELL VOLTAGE: 3.375 V | SOC RESET CELL VOLTAGE: 3.650 V | SOC_RESET_AFTER_DAYS: False
INFO:SerialBattery:> MAX BATTERY CHARGE CURRENT: 100.0 A | MAX BATTERY DISCHARGE CURRENT: 200.0 A
Well crap. it worked on the test Pi GX. with the Can Hat. but dont work in my live Cerbo enviroment on a BMS Can port. it is detected but no telemtry. only voltage. Not sure what im doing wrong.
