I don’t connect to it via Bluetooth in VRM either; I do that through a GlobalLink. In the GlobalLink, I can use VictronConnect to see which Bluetooth devices are connected. There are four, including the IP22 charger. However, the data isn’t visible in VRM. If I click on the charger in the GlobalLink, it then becomes visible. But if the 230 V supply has been disconnected, the data is no longer visible. Surely a system that can be monitored remotely shouldn’t require one of its components to be activated via VictronConnect.
The IP22 does indeed need to be connected to 230 volts. The annoying thing, though, is that when it’s reconnected to 230 volts, it becomes visible in VictronConnect again, but this isn’t passed on to the VRM network. It only becomes visible in VRM again once you tap it in VictronConnect.
I have a globallink 520 on my standby house system, so will try and get the van close enough to connect the IP22 and see if it shows the same behaviour.
As an aside, if you have internet available at this location, I can recommend the Boardstrom app. I have this in my camper running on an old Android phone with the Pro version and can then monitor remotely. All Bluetooth devices including the IP22 seem to work perfectly (although 230v is disconnected right now so not showing in the screenshot below)
I have a GX device on the main house system, GL520 on the shed standby, and now trying out Broadstrom in the camper. A good mix
I have just been trying to get the camper close enough to the shed to try and connect the IP22 to the GL520 by Bluetooth , but sadly no joy even at around 5M distance, so I have been unable to test mine and see if does the same as yours.
