IP22 12 - 30 (3) Absorption Voltage
Today I discovered that I CAN select an Absorbsion voltage of less than 12.8v on an IP22 12-30 (3) charger, despite that being the minimum setting allowable when you make your settings via “User defined” perameters. If you type, 12.5 when you press OK you get 12.8v.
HOWEVER if you select a “preset” created by another charger that does allow lower voltages i.e. an mppt you can achieve a lower Absorbsion voltage.
Reader alert I’ve only tried this in the demo library whilst responding to another users query about cold charging. My RV is several thousand miles away as I’m travelling and won’t be home to physically try it until mid November but if anyone else has an IP22 and is bored for 10 mins and has time to tinker, I’d be interested in the results.
Background
I run NMC batteries in my RV simply because the power density was the best choice when I built the system a few years ago. Possibly not the case now, but hey ho. I am where I am, my system works great and I’m more than happy with it.
One of the characteristics of the 3S NMC cells is a fully charged voltage of 12.6v thus your chargers need to be capable of charging this low.
All the Victron chargers in my system (Mppts, Orion XS, Multiplus) are happy to charge at a voltage lower than 12v and I have a couple of charge profiles as low as 11.5v absorption for when the RV is dormant for months and I want a low DoD to prolong the life of my 900Ah setup.
The exception is my 240v 12 - 30 (3) IP22 charger. If I go into “Advanced battery settings” and user defined settings and try to set the Absorbsion voltage, the minimum allowable is 12.8v
I resigned to the fact that I’d need a workaround and designed my system so that the IP22 and a second solar array and Mppt charge the chassis battery and then an Orion XS charges the House battery from it. The main solar array and Multiplus also charge the house battery.
I’m happy with the setup as both batteries are always charged but I’d be interested to know if a firmware tweak would make the IP22s more adaptable for others designing bespoke systems. Or maybe this workaround might help someone else if it works.
