Inverter Remote Switch Clarification
Hi all,
I would like to get clarification regarding the inverters remote switch capabilities. I know that on the regular multiplus inverter, the remote switch is not able to be wired/used while the VE.Bus BMS NG is also hooked up to the inverter.
Does the same apply to the Multiplus II or since that is a newer model, has it integrated all of the modern software/components allowing the remote switch to still work despite a VE.Bus BMS NG being hooked up also?
Thank you!
The BMS remote on/off terminal can be used to turn the entire system on and off while the BMS remains connected to battery positive, which keeps the inverter in low power (discharging and charging not allowed) mode even if it is still connected to AC In.
The remote terminal for the BMS Ng is designed to switch off the entire system.
