Multiplus 24/3000/70
I’m having a new and rather strange issue, I live full time in my camper, and I’ve had this system up and running for over a year. Two nights ago I arrived at a campsite, plugged in like usual but was getting really inconsistent power from the 30 amp outlet, and you could hear it buzzing at the connection and the LED light on my cord was flickering. So I switched to the 20A plug and called it a night, everything was fine.
But in the morning, my inverter disconnected from shore power and wouldn’t reconnect. I tried fiddling with the plugs, and ultimately pulled my generator out (Honda 2200i) and plugged it in, and I had shore power again.
So, I figured it was the campsite, even though when I tested it with my Fluke, it would show 124~ volts and 60hz. Called the front desk, and they moved me to a different spot, but same problem. Called again, moved to a spot with 50 amp service that was newer, plugged into the 30 amp plug and still it won’t take power. I can hear it clicking on and off occasionally to try to connect, the touchscreen shows my available input currently at 120v and 60.3hz, but it won’t accept it.
Again, it will work if I plug in my generator to the same plug and cord.
Edit:
Just wanted to add a bit more info, so I plugged in the MK3 to take a look at some of the settings
I do have accept wide input frequency range on
I have virtual switch off
My voltage connect and disconnect settings are such that it should easily accept the voltages I’m seeing, nothing too wild, I’ve seen between 119 and 124
I can watch the little Mains bar countdown thing to the click, so that’s a cool little feature, so now I know it tries to connect every 4 minutes.
Ideas?
