Incorrect SmartShunt Wiring Layout
Hi All,
I have just had a new victron system installed on my narrow boat - Cerbro GX, Orion Smart, SmartShunt, Smart Solar, SuperPack NG. The smart shunt isn’t showing the correct state of charge - it often shows 100% charge when the SuperPack NG shows around 20%. I think the electrician who installed it has wired it up wrong. He has connected the negative of my starter battery to the negative of the SuperPack NG which in turn is connected to the smart shunt. This doesn’t seem to be correct according to the victron manual which show that the negative of the starter battery should be connected to the loads and chargers line. Could this be why the smart shunt is unable to display the correct state of charge and is this likely to cause other problems/hazards with the system?
Thanks,
Alun
Yes, that could well be! Let the two of them split up.
That has to be the most common mistake made with the shunt installation.
In theory no hazards unless there are loose connections; but yep bad SOC readings are the result
Only the negative terminal of the battery being monitored should be connected to the “Battery” terminal. Nothing else! All loads and charging sources should be connected to the other terminal (System). Check this and, if in doubt, send some photos.
All coulomb meters (including the SmartShunt) become inaccurate over time. That’s why you can synchronise them. There are settings for this in the shunt under “Battery”. Send a screenshot of those. That could be the cause.
Yea I’ve checked this there is a cable connecting the starter battery negative to the house battery negative and the electrician has confirmed that that’s how he set it up. My problem is the electrician who installed it insists that it’s correctly set up and says it’s a software setup problem. Not sure how to handle this :frowning:
Show electrician the attached, 5A i believe is suutable.
Quick_installation_guide_-_SmartShunt_IP65-en.pdf (1.1 MB)
I’ve done that. He’s not budging, insists that the SOC is only measured from the voltage. It’s so frustrating - cost £11,000 to get it installed by a marine electrician if I change it myself they will say they’re not responsible for it anymore.
Your installer has got it completely wrong.
There should only be one cable between the battery negative and the shunt. The negative terminals of all loads and chargers must be connected to the shunt at “to system minus”.
Tell him EVERYONE says he is wrong, including Victron the manufacturer of the shunt. You can’t measure SOC accurately with just voltage. This is all elementary electric tech.
I get it that your in a difficult spot but dang! This guy claims to be a professional and wont even read the manual?
The colleague needs a bit of help. Show him the link to Wiring Unlimited, as well as:
If he’s a registered Victron installer, recommend that he do the training again!
Oh dear. And I guess the shunt manual isn’t changing his mind. Oi.
Thanks so much all of you. I was starting to doubt myself but you’ve reassured me that I was reading the manual correctly.
Is this chap qualified or a self made “marine electrician” ? Is he a Victron dealer and supplied the kit? Or did you buy the kit from a separate dealer and he installed.
Who is this person so that forum can avoid??
The Victron stuff counts Ah in and out. Some kit calculates SOC from the voltage, e.g. Smartguage.
That installation guide/drawing is a bit simplistic and is possibly open to too much interpretation, but it clearly shows the correct second battery connection.
I would carefully document the situation, take photos, and rectify myself. It is only one wire to move. Especially if he didn’t provide the kit, so isn’t the dealer for any warranty.
But I’m not convinced the Victron “third party” dealer warranty arrangements are any good - I have recently raised a support ticket and the supplying dealer hasn’t even responded after a week.
