Incorrect labels on DESS battery settings?
I believe that the text labels for the battery restrictions on the Advanced Settings are not correct.
When you switch between the restrictions for charging or discharging, the configured times will change - suggesting that is a different group of settings - but the label on the toggles is always “Restrict discharge”, which is confusing.
