We have 5 pcs of 200 Ah Li 24 Volt. And a LYNX Smart BMS. Normally charged by MPPTs. Se picture.
One of the batteries “Epsilon” is showing a lower Voltage (About 0.1 V). It does not matter to move it. Still it is that specific battery. So not cabling issue.
And it shows “Balancing/Imbalanced” even if it looks pretty balanced to me.
Have tried to increase charge time - but it seems only way is to disconnect all other batteries and just charge the imbalanced. Then it will go balanced for a few months.
I have a theory that this battery want a (slight) higher voltage - but the other batteries prevent the BMS to supply this.
Maybe bad Voltage measurement (should be same all over - right?)
Any ideas?
