I need help Victron 150/85a Controller, battery to inverter
Hi I am new to the community and solar set ups. I have 4 x 240w 12v Isc 10.98a solar panels that i want to set up as 2 strings in parallel. Each string with a 40a dc breaker. I will be using 6mm cables to a Victron 150/85a charge controller. I also have a Renogy 3000W inverter and 4*100ah 12.8v lifepo4 1280wh batteries. I was advised to set the batteries up in series+parallel. I am confused with the cables I need from charge controller-> battery->inverter. I also know I need a battery isolator switch and fuses. Does the battery isolator run between the battery and inverter or the charger controller. Yes, I am a complete novice and don’t know where else to turn for help. The set up will be my garage and solar panels on its flat roof.
Do you have 4 Ă— 240 W modules?
As a beginner, you should team up with an electrician and plan the system with them!
It is not possible to simply connect batteries in series or groups of them in parallel if the BMS does not support this! This only works with master-slave systems and corresponding BMSs that can be coupled, for individual battery blocks.
Check under Where to buy to see where the nearest specialist is.
I had an error in my message. Yes its 4 x 240w solar panels. I just corrected the error. Thank you for your valuable advice. It just so happens an electrician friend is doing work on my house and I will get his support on this.
Run your config through the calculator.
There are two rules for the victron mppts do not exceed input voltage under the coldest temperature. I have a feeling you will exceed the 150v here with that much power.
And do not exceed the input current limit for the parallel strings. The strings mug also be symmetrical.
Is this a 24volt inverter? You will probably need some battery balancers as well. Battery bank wiring explanation.
Ideally one for each and fusing
Use a notepad and draw it out. A basic drawn plan will help clear up a few things.
This is a neat resource for beginners.
Hi LX,
I had an error in my message. Ive corrected it. it’s 4 x 240w 12v isc 10.98a solar panels. The inverter is 3000w 12v. Thank you for reaching out and for the links. I will read up on this. I am so glad I joined this forum. I will still also seek the help of my electrician friend. Everything is still boxed up because I don’t want to electrocute myself.
