I did some modifications to the signalk server and need to restart it
After some mods the system said to restart the signalk server. Is there a way to do that within signalk or within Venus OS
Choose the reboot GX option from general settings.
Or kill / restart its process and the OS will take care of things… It’s quicker.
Making some mods means you have some knowledge of the OS. :slight_smile:
There is also Restart option in SignalK dashboard (top right) if you are logged in as admin.
I am the admin, but I don’t have the restart option in the top right. How can I assure my setup is correct?
on small screens you should have a burger bar top right with login button or if already logged in with logout and restart buttons
I have the burger bar but nothing when I touch it
how do you login then? if there is nothing?
If you are not logged in, then you should have Login on top right corner. And there are less options on menu on the left:
that´s why I am wondering because in OPs other thread he posted some screens where he tried to configure the data connections - which shouldn´t be visible if not logged in!
