I built a dedicated round display for Victron systems — looking for beta testers
Hi all. I wanted to share this product I’ve been working on for the past few months. Mostly I just wanted to see if it was possible, and turns out it is and I quite like it.
It is an ESP32-based round knob display that subscribes to the Cerbo GX MQTT to show basic info at a glance, and a nice watch face. The idea is to be a “dumb” dashboard focused on camper vans. It does not have fancy home assistant graphs and insights, doesn’t turn lights on/off, doesn’t have a gps or a level meter. You rotate through the screens to see the info you want, and the only thing touch does is wake the display from a dim state.
I work at a company in Edmonton, Canada building camper vans. The idea for this came when I saw that the VenusOS on a GX Touch is a little too much for a lot of people that are not really into technology or don’t understand the system. People mostly just want to know if they have water for a shower or what the SOC is before they go to bed with the A/C on.
It connects via WiFi and can also control a heater blower via a Bluetooth relay board. So it’s not hard to retrofit it to an existing setup, it’s mostly wireless.
I posted it in a Victron Facebook group and got a lot of “do you sell this?” comments, which is what pushed me to do this properly, so I’m trying to put together a small beta batch to get units in other builds, and shake out the edge cases on systems I can’t test here.
The firmware is stable and the display is fully functional. What “beta” means here is that the enclosure is functional but not final — it works and looks clean, but the housing will get refined before any production run.
I’m not selling anything in this post, just building a list of people who’d want in on the beta, so I can make sure everything you run is supported. No commitment, no money up front. Details on price, timing, and how slots work will follow once the batch is confirmed.
If you want on the list, there’s a short form here (it asks about your setup so I can check compatibility): Helm Gauge - Victron-native round display (beta batch)
Happy to answer any questions in the thread.
Thanks for taking a look!
Felipe
What information can it display, and is it suitable for outdoor use? (boat)
Currently it displays time (using the Cerbo battery backed-up chip), cabin temp, battery SOC, current usage and time-to-go, charging input separated by shore power, alternator and solar (with input amp limit setting for the shore power), inverter power draw and switch on/off (switches only inverter, charger keeps on), tank usage (fresh, grey and black) and heater blower control with temp sensor.
It is more focused toward camper van / RV, so it’s not outdoor rated.
Doesn’t display any of the Boat Page (motor drive) info then, which is why I was asking… :frowning:
