How to solder V-CT100-WE wires to jack
I mistakenly bought a CT100 with wire ends and need a jack to connect it to my EasySola II-GX. Would someone know how to solder those wires onto a stereo jack?
Soldering can be omitted if you not comfortable with soldering.
You can but a pre wired jack plug and use non soldered electrical connector.
Attached spec sheet for a pre-wired ct clamp to assist with wiring - only 2 wires to connect and if you wire wrong way round the clamp will be reversed flow which won’t harm anything - if this is the case swap wires.yhdc.pdf (800.1 KB)
Thanks
