How to restart a Quatro remotely or toggle AC output?
The installation is remote but w/ VRM access. I need to toggle AC output in order to restart a device that is powered by AC. The installation has a battery pack and an AC source that is always connected to AC in2. Internet access is DC powered.
VRM and CerboGX have On/Off/Inverter only/Charger only switch for the Quatro.
What will happen if I toggle On/Off? I’m afraid that after I switch to Off the Quatro will switch off forever until manually switched back.
Off is off.
If it switches off your router for internet (powered from inverter output) and thus your control over vrm- then yes… Its off until physical intervention.
In theory in charger only mode it will allow passthrough. But may have a blip and you have to wait for a reboot of the router and internet connection to the GX.
(Make sure reboot on not contact is on)
Router is powered by DC. So the Internet access is not depended on AC.
You will be able to turn it back on without an issue.
I confirm. Turned back successfully.
