How to reduce grid consumption
Given that over time I’ve managed to consistently integrate my system, which now consists of:
1 MultiPlus II 48|8000|110 Inverter
3 150|60 Charge Controllers
3 Groups of photovoltaic panels, total 12 kW
5 Pylontech US5000 Batteries
1 Ekrano
I’m finally able to meet all my home’s electricity needs.
However, as the number of electricity-consuming devices in my home has increased, the use of the grid, which supports frequent power surges, is keeping grid consumption at around 10%, whereas previously in the summer I was able to keep it around 3%.
Which of these settings is best to adjust to reduce grid consumption?
Settings > Devices > Inverter > Grid Current Limit… e.g. 16.0 A
Settings > Devices > Batteries > Inverter > Grid Current Limit… e.g. 16.0 A
Settings > System Configuration > ESS > Grid Settings… e.g. 50 W
Settings > System Configuration > Charge Control > Maximum Charge Current… e.g. 100 A
This one, if your allowed to feed to grid then make it a negative value
Also consider using this.
You don’t want to do this, it will limit the solar as well.
If you don’t want even 1 watt when not necessary from the grid just AC ignore or switch to inverter only.
Automation of that has so many possibilities.
