Hello
Recently I installed a Victron MPPT RS 450/200 to my existing system. So far everything works as expected together with my three Multiplus II and the battery.
But as I have too much power installed (for summertime), I like to temporarily disable one or two of the four installed trackers. In the CerboGX release notes of firmware v3.73 I found “Add RS tracker enabled/disabled paths.”, so I expected to enable/disable each of the four available trackers in NodeRed after the firmwareupdate of the Cerbo GX. But in the “SolarCharger Control” - Output Node I can just see the “Measurement” to Enable/Disable the charger completely or to set the max amount of current (A). Is it still not possible to enable/disable each of the four trackers ?
