How to configure Victron with Tristar TS60 diversion control
Hi I would appreciate any feed back on charge control settings with a water turbine (output max 10 amps but continuous in the winter).
If I set the Tristar TS60 to low it will divert the total output from solar and water. I only want to divert the water turbine output. I am using a dump load with resistors at this time.
If I set it too high the BMS may cut in
Dyness parameters are ;
Bulk 56.5v
Absorption 56.0v
Float 55.0v
The Dyness BMS will shut down at 57.6v
The MPPT throttles back at 56.8v
My question is what settings for the TS60
Do I equal or a fraction above the MPPT settings.
My setup is Multiplus II 3000, Cerbo GX, Mppt 250, 4kw solar panels and
Dyness DL5.OC 48v lifepo 400ah, Morningstar Ts60 for diversion.
I can configure the Tristar settings in MS View, (a bit clumsy and awkward) Water turbine output is max 10 amps at 48v
Thanks for your attention
