How To: Adjusted Modbus Client Polling Interval in Venus OS
Hi there, can someone from within Vicron tell me?
How to Adjusted Modbus Client Polling Interval in Venus OS: I tried to connect to the Cerbo GX via SSH (PuTTY) as root. Modified /opt/victronenergy/dbus-modbus-client/dbus-modbus-client.py. I changed UPDATE_INTERVAL from 100 ms. to 10000 ms (10 seconds) and tried 20000 ms (20 seconds) to reduce load on the Enphase hardware. No luck.
What is the correct spot and variable to lower the polling interval?
Thanks
My updated settings in the dbus-modbus-client.py files look like the once below but didn’t resolve the polling interval issue. Your help is appreciated.
FAIL_TIMEOUT = 5
FAILED_INTERVAL = 10
MDNS_CHECK_INTERVAL = 600
MDNS_QUERY_INTERVAL = 1800
SCAN_INTERVAL = 600
UPDATE_INTERVAL = 20000
