How does DESS handle smartgrid heatpump
Hey all,
In the Netherlands net metering will stop end of this year so that means DESS needs maximize self usage of energy.
This also includes taxes, so importing will cost tax and exporting won’t give it back.
I’m trying to find out if a smart-grid heatpump is worth it to use cheaper tarrifs.
I have two options in winter:
  • Boost the heatpump at cheaper tarrifs and lower it at high tarrifs
  • Pro’s: cheaper tarrifs, more self usage of solar, less conversion losses, pleases me as a nerd,
  • Cons: lowering COP, can result in shorter runs and lowering lifespan of the compressor, less predictable for DESS, cost of a pcb, less steady temperature
  • Run the heatpump steadily 24/7 (battery does smart import)
  • Pro’s: Higher COP, more predictable for DESS, being nice for the compressor, steady temperature, no costs
  • Cons: Could be more expensive, conversion losses of battery
For most factors i know the pro’s and con’s but i’m not sure how the battery handles smart grid heatpumps.
Will it have more trouble forecasting the loads?
For example, in the Netherlands we have a lot of wind power so even in winter there can be really cheap tarrifs at night.
A smartgrid heatpump will shift a lot of energy from morning-peak to the night which will effect how much energy the battery needs to import during the same night.
I dont want the battery to buy a lot of extra energy at night and export solar during the day because the battery is full and the heatpump is off/low.
Just my thoughts on the matter.
I hope there is someone here who has more experience with this specific topic.
Extra context:
My heatpump uses 15kwh per day at most in winter, 90m2 underfloor heating (even the attic) so i can shift a lot of energy.
16 kwh battery, inverter is a victron MultiPlus-II 48/4k5/55-32, so the battery can be charged in 5 hours and spread that energy all through the evening, night and morning.
Solar setup:
  • west: 8 panels 45 degrees
  • east 8 panels 45 degrees
  • south 3 panels 45 degrees
  • flat 6 panels
