Hi, I am DIY. Which MPPT do I select.
Solar Panel (Pmax) 315 W
Open Circuit Voltage(Voc) 46 V
Max Power Voltage(Vmp) 38 V
Max Power Current(Imp) 6.45 A
My existing system is LiFePO4 12.8v, 100Watt
Which MPPT do I choose?
Thanks, WineO
Thanks, WineO
Use the mppt calculator
As above use calculator.
If you may be considering upgrade at a later date, use calculator / get next size up mppt for possible upgrades, going up a size wont hurt , as long as it suits battery voltage.
