I only have 2 mopeka bluetooth sensors for my Cerbo GX.
I have a bluetooth adapter for better bluetooth.
For some reason I have 1 ghost sensor name “Svartvatten” - how do I remove “it”?
Good afternoon,
It looks like a tank sensor instead a Bluetooth sensor, maybe?
Check the tank sensor input settings.
Regards, Jeroen.
Good afternoon,
Good, that’s not it then.
Check the name in the gas oil menu, maybe there it has that name given to that tank.
Regards, Jeroen.
I cant find the sensor in the settings. It’s like ghost, just showing up in the “Panel” ![]()
I suspect I had it installed on the build in bluetooth reciever, but I cant find it anywhere and cannot remove it.
Good afternoon,
I can see it I think…in the last photo, gasol…touch the right arrow and see what it says there?
Regards, Jeroen.
Good afternoon,
Ok understood, now you see below the installning button, check there if you find that “ghost name”, and do so for all other sensors, if you do not find that name, reset to factory settings and programm everything from scratch.
Regards, Jeroen.
I would like to avoid factory reset.
Any other ideas?
No idea where this tank comes from, but you can change what you see in this overview under Inställningar → Allmänt → Visning och utseende → Kort sida → Nivå 4
Regards,
Thiemo van Engelen
