Help with MPPT 150/35 Bluetooth Connection
I have purchased a used 2025 Airstream Basecamp. When trying to connect via Bluetooth, my MPPT will not connect due to a previous pin. I have tried all the default ideas (000000, 0000, 1234, etc.) I would like to reset. I have scoured the MPPT and no label with PUK # is attached. My MPPT does not have a mode button. I have called Airstream, they cannot help. I have S/N but can’t find anyone who might be able to supply PUK#.
Just for Clairification…NO Label with a PUK# is on the unit. Not front, Back, sides, heatsink, etc. Sorry but I went on for about 20 minutes with Airstream telling me that this is simple, just “Look at the Label” Noooooooo!
I understand that one option might be to buy a special cable and hardwire to laptop. Would this work to change the Pin? or will I still need to have the present PIN in order to change to a new Pin?
Any ideas would be most appreciated.
Just to make sure, you are working with a SmartSolar not a BlueSolar correct? BlueSolar is not Bluetooth and will need a VE Direct Smart dongle installed to access it. If it is in fact a SmartSolar MPPT, the PUK is very small on the very bottom of the label. I know you have looked but it can be hard to see if the unit is installed already. Perhaps remove the unit to get a closer look. I have never, ever, ever seen a SmartSolar without a PUK on it from the factory. If someone did remove it then I am not sure how to proceed. Find yourself a Victron dealer and see if they can do anything using the serial number.
To answer your question, you can access the unit settings through VictronConnect using a USB to VE Direct cable, or like I suggested earlier, a VE Direct dongle. You still won’t be able to change the PIN this way. I am pretty sure, as a last ditch work around you could use a VE Direct Dongle permanently to give you bluetooth connectivity without the old PIN. The dongle would become your bluetooth connection and have its own PIN. You will see the USB to VE DIrect and the VE Direct Smart Dongle are about the same price.
Did you try to ask the previous owner for the PIN?
With the serial number you could use this form:
https://www.victronenergy.com/support-request
Hey thanks. Yes. He was not sure the camper even had Lithium Batteries. They had NEVER used the Airstream. Stock numbers, labels all still in place (HaHa except the PUK label on the MPPT. I think I have discovered that the Smart MPPT is the only one that can be used Bluetooth without the Dongle. I am pretty new at this and did not realize this. Mine is not the “Smart” controler and neither am I.
Yep, You hit it right on! I am now educated. Even though the BlueSolar shows up in the app and asks for a pin, I guess it will never connect without going through the Bluetooth Dongle. ?? Quite a teaser, I mean their it is, just asking for a pin, not telling me that no pin exists, no PUK exists. Victron = pretty smart stuff, but not smart enough to tell a customer that the device that shows up in your app waiting for a pin, will never work no matter what pin one uses? Hmmm, Yep learned a lot yesterday!
Thank you so much for taking the time to answer this post. I honestly appreciate the time and effort you have taken. I am not sure how to close out this post so it displays “Solved” I will see if I can figure it out. Maybe I need a pin?
No problem. Happy to help. I didn’t realize you can access a BlueSolar controller in the app. I’ll have to check that out. For the record, you click “solution” on the reply that actually helped you resolve your question. In other words, my reply. :grin:
