Help protective box choice
Hello guys,
Your help would be very appreciated, i’m going to buy the following kit, but with the 5000VA EasySolar II-GX - Victron Energy :
I would like to know, wich AC protective box and fuse i could choose, wich DC protective box and fuse, and wich Battery protective box and fuse i could choose ?
It is for an offgrid installation, knowing that protective box are not an obligation but i would like to install it anyway
Thank you very much
Best regards
It is very difficult in an international forum to make recommendations as regulations vary from.country to country. This also falls outside of specific Victron equipment. I suggest you consult a local electrical installer.
You’re right I understand, thank you for the time you took
