Subject: Seeking Guidance: Integrating 1-Phase AC PV Inverter with 3-Phase Quattro System (No MK3 Dongle Available)
Hi Victron Community,
I would like to express my sincere appreciation and admiration for Victron Energy’s engineering and reliability. I am a proud owner and daily user of a Victron system, and it has been performing exceptionally well.
My Current Setup:
Inverters: 3x Victron Quattro 48/5000/70-2x100 (configured in a 3-Phase system).
Storage: 48x Tubular Gel Batteries (48V / 1600Ah bank - 76.8 kWh total capacity).
Solar DC Charge Controllers: 3x Victron SmartSolar MPPTs.
Monitoring: Color Control GX (CCGX).
Existing Solar Array: 30x 330W panels (~9.9 kWp nominal) connected via MPPTs.
The Challenge:
I am trying to integrate an additional 5kW single-phase AC-coupled solar inverter (connected to a secondary array of 70x 150W panels) into the system to boost battery charging capacity during peak sunlight hours.
However, when connecting the AC output of the 5kW inverter to AC IN-1 of the Master Quattro phase, the system triggers VE.Bus Error 19 (“Slave does not have AC-input”) because single-phase AC is only present on the Master unit while the system is set to Switch as 3-phase.
Due to my location in Yemen, I face two significant obstacles:
Lack of Local Technical Support: There are no certified Victron dealers, official technical support, or experienced engineers nearby to help clear or reconfigure phase settings.
Hardware Constraints: I currently do not possess an MK3-USB interface dongle to connect VEConfigure and modify the Switch as 3-phase or phase-loss interlock settings directly.
Putting the Quattros into Charger Only mode still produces Error 19 when AC is detected on only one input, preventing us from safely utilizing the full output of the 70-panel array to charge our battery bank while keeping the 3-phase household loads operational.
I would deeply appreciate any advice, workaround, or remote assistance guidance from the community experts on how I can safely resolve Error 19 and utilize this AC energy source without an MK3-USB adapter at hand.
Thank you all for your time and continuous support!
Hi, what if you let the single-phase inverter synchronise with your three-phase system?
So your 400 V system provides the “grid” reference, and then your three-phase system effectively charges the batteries in reverse.
As far as I know, that should work — or have I misunderstood your setup?
Are you running the three phases on the AC-OUT or in grid-parallel mode?
I wouldn’t connect the single-phase unit to the GX. I’d try it this way, or let the single-phase unit synchronise with the grid as in an ESS system.
I don’t understand the sentence “connected to a second system…”
System Mode: I am running a completely Off-Grid 3-Phase system (3x Quattro 48/5000 in Switch as 3-phase configuration). There is no public grid available here.
Clarification on “Second System”: I meant that I have a secondary, separate PV array consisting of 70x 150W panels connected to a standalone 5kW single-phase AC PV Inverter, in addition to my primary 30x 330W array connected via DC MPPTs.
Connection Idea (AC-OUT Coupling): Your idea of connecting the single-phase PV inverter to AC-OUT 1 of the Master Quattro instead of AC-IN sounds promising to bypass Error 19! However, since I do not have an MK3-USB dongle to configure frequency shift power control (Factor\text{ }1.0\text{ rule}) in the Master Quattro, will connecting a 5kW AC Inverter directly to AC-OUT 1 cause any overcharging issues when the battery bank is 100% full?
Here is a quick diagram of my proposed vs current setup:
[Current Attempt]:
PV (70 panels) \to 5kW 1-Phase Inverter \to AC-IN 1 of Master Quattro \to Triggers Error 19.
[Your Suggested Setup]:
PV (70 panels) \to 5kW 1-Phase Inverter \to AC-OUT 1 of Master Quattro (Feeds household loads directly & back-charges batteries via Master Quattro).
Due to the current situation and severe shipping/logistics restrictions in Yemen, importing electronics or ordering specialized equipment like the MK3-USB dongle is extremely difficult, unreliable, and can take months to arrive—if it arrives at all.
There are also no local official Victron distributors or suppliers in my area who carry this accessory in stock.
This is why I am currently looking for an alternative operational workaround or a way to utilize my secondary solar capacity safely without relying on the MK3 interface for now.
What PV inverter do you have exactly?
Normally a AC PV inverter shouldn’t even start producing an AC voltage without being connected to a grid.
It’s strange that your PV inverter tries to start at the AC IN.
With an internet connection you should be able to change settings of the VE.Bus system remotely:
Thank you for all the helpful feedback so far. Before I proceed with the wiring, I want to double-check a specific point regarding the connection to ensure full safety and avoid any hardware damage.
My Current Setup:
3x Victron Quattro 48/5000 (configured in a 3-Phase off-grid system).
1x 5kW 1-Phase Grid-Tied PV Inverter (connected to a 70-panel array).
48V 1600Ah Tubular Lead-Acid battery bank + 3x SmartSolar MPPTs.
Constraint: No MK3-USB interface and no internet connection on-site for remote configuration.
The Proposed Connection (AC-Coupling on AC-OUT 1):
I understand the recommendation is to connect the 5kW single-phase PV inverter directly to the AC-OUT 1 terminals of the Master Quattro (Phase L1), rather than AC-IN 1 (which triggers VE.Bus Error 19 due to phase imbalance).
My Specific Question & Safety Concern:
To clarify the physical wiring:
Am I supposed to connect the Live (Phase) and Neutral output wires from the 5kW PV inverter directly onto the exact same terminal screws of AC-OUT 1 on the Master Quattro, where the existing household output cables are currently connected?
Specifically:
Live (L): Joining the 5kW PV inverter’s Live output wire together with the existing Live output wire under the AC-OUT 1 Live terminal screw?
Neutral (N): Joining the 5kW PV inverter’s Neutral output wire together with the existing Neutral output wire under the AC-OUT 1 Neutral terminal screw?
My main concern is whether feeding AC output power from the 5kW PV inverter directly into the active AC output terminals of the Master Quattro will cause any phase conflict, short circuit, or damage to either inverter when both are running simultaneously.
(Note: I am fully aware that without the MK3 interface to set up Frequency Shift / PV Inverter Assistant, I must manually monitor the battery State of Charge and switch off the 5kW PV inverter breaker once the batteries reach 100% / Float voltage to prevent overcharging).
Could you please confirm if this physical parallel connection on AC-OUT 1 is completely safe and correct for this setup?
Unfortunately, I do not have a stable internet connection on-site for the CCGX, so using Remote VEConfigure via VRM isn’t an option for me at the moment.
Therefore, I will proceed with connecting the 5kW 1-phase AC PV Inverter directly to AC-OUT 1 of the Master Quattro and manage the battery state of charge manually by disconnecting the 5kW inverter breaker when the battery bank reaches 100% (Float voltage).
Thank you all for your clear guidance and support!
Are the inverters wired as a three-phase system on the input side? In my view, a single-phase feed into a three-phase system should definitely trigger a Gridlost or similar, since in a 3P system, the loss of two phases is always a fault condition.
And that’s exactly what the fault description says.
A system configured as three-phase can’t operate with ACin bridged either, imo — the missing phase shift will also cause a Gridlost.
My Current Setup:
Specifically:
So, for example, a Quattro as a 3-phase system.
The loads are connected to AC-Out 1.
PV-2 / the additional PV inverter should be connected to AC-In 1 of the first inverter.
According to the manual, you can connect another inverter to AC-Out 1 or 2, provided it can synchronise with the AC-Out. When the battery is full, it will then shut down due to the increased frequency. Page 2.
But according to the manual, it should also work if you configure an AC-In as a generator or something similar. Page 10.
You may need to make additional settings using the DIP switches. Page 16.
Error 19: As far as I know, you need to bridge that phase to all the AC-Ins, and use the DIP switches to limit and set the charging current.
My 5kW PV inverter is an Off-Grid Hybrid Inverter, not a grid-tie unit (like Fronius/SMA).
When I tried connecting its AC output to AC-OUT 1 without connecting its own 48V battery DC terminals, the hybrid inverter immediately threw error F08 (Bus Voltage High) and shut down because its internal DC bus couldn’t handle the AC coupling without a physical battery reference.
Regarding AC-IN 1 and bridging the phases to avoid Error 19: since I don’t have the VE.Configure software/MK3 interface on-site to adjust phase parameters and charge currents safely, bridging AC-IN is a bit risky for my 3-phase Quattro setup.
So the best path for me now is to connect the main 48V battery bank directly to the hybrid inverter’s DC battery terminals first.
Keep the three phase Victron system always inverting. This way no reprogramming is needed.
Use the other hybrid to charge from the single phase grid that you have available.
Do not use it’s AC output for anything, do not connect it to any of the victrons withe input or output. unless you want to separate out some loads in your electrical distribution board?
You can still use the growatt to charge the main battery bank from grid. If you want to meter is in some way on the victrkn system it is possible. But that can be tackled later. Just get it functioning first.
To answer your question: Yes, we do have a 3-phase grid available, but we use a manual 3-phase Changeover Switch at the main distribution board. The house loads switch manually between the 3-phase grid and the 3-phase Victron system output.
Your proposed strategy (DC coupling via the 48V battery bank) makes complete sense to avoid Error 19 and F08 without needing an MK3 interface.
However, I have very little experience with the physical wiring and I’m not sure exactly where and how to connect everything safely.
Could you please guide me step-by-step on:
DC Battery Connections: Where exactly should the DC cables go from the 48V tubular battery bank / busbar to the OPTI-Solar inverter? What cable thickness and DC breaker rating should I use?
AC Connections: Should the OPTI-Solar’s AC-IN or AC-OUT be left completely disconnected, or is there any specific breaker setup needed?
PV Connections: Where do the 70 solar panels connect into the OPTI-Solar?
A simple layout or wiring sequence would be greatly appreciated!
Regarding the manual changeover switch: We use it mainly for full isolation and safety because the Victron setup isn’t programmed via VE.Configure/MK3 to auto-transfer the grid yet, so we prefer switching manually to avoid any configuration conflicts.
As for the extra OPTI-Solar inverter, our main goal is simply to utilize the additional 70 PV panels as a pure DC solar charger to keep the 48V battery bank topped up.
Thank you so much for your great support and guidance!
