Good morning,
I have two MP2s. Under FW v3.60 the debug & develop application is available, under v3.67 it is not shown up .
Any idea how to activate the feature in general ?
Good morning,
That option is only available if you are logged on as SuperUser. Did you check that you logged back on as SuperUser after changing firmware.
Just in case, to set SuperUser
1.Press/ click and hold on the line where it says “Access level”
2. Whilst still pressing/ holding the line, drag the line down to the bottom of the screen
3. Hold the “Access level” line at the bottom of the screen for 5 seconds
4. It will change to Superuser on its own
5. Once it says Superuser let go.
Hello pwfarnell,
perfekt !
Thank you very much for your fast response and solution
alf007
Yes, I’ve done an upgrade to v3.67 and then to the beta version v3.70~74. The SuperUser always remains, also a fallback to v3.67 kept the SuperUser.
Thanx a lot ![]()
