I have a 5kva multiplus easy solar with 4kw solar and 10kwh batteries. I have a backup generator connected to it. This is at our original offgrid house and we then added another house with 2 x 5kva Quatros in parralel with 8kwh battery without its own solar.
The house with solarpanels provide a grid connection to the second house.
I set the grid current limit on the second house to 6 amp and the batteries are charged at that rate. When a load is drawn on the quatros it exceeds the 6 amps and will go as high as is drawn to the point where the easysolar trips.
I had the quatros at my house in town on grid and it never exceeded the grid connection. It suplemented the grid with battery or solar but never ecceeded the grid. The only difference was that I had a gridmeter installed. The power assist function doesn’t make difference.
I tried different settings but it doesn’t make a difference. I want it to work when it was connected to a grid, just use up to the limit supplied and supply the difference from battery.
