Getting rid of Custom Startup Scripts
Apologies for bringing up an issue that has been discussed before. That topic was closed, so I had no other option than to start a new one again.
My issue is that the Support status on my Cerbo says that I have installed and enabled a custom startup script. I am 99% certain these are left overs from the initial UI improvements a few years ago. Now that the UI has been significantly improved (Thanks Victron!!!) I don’t need those custom scripts anymore I presume and would prefer to have a default installation. But I am very hesitant to press the “Disable and Reboot now” button.
Can someone please tell me (in bullet point steps) what I need to do to get to a default installation without wrecking my system. I am currently traveling in my camper and absolutely do not want to be stranded with a system that stops working. PS, the image below is copied from the other thread so the HQ Serial number is incorrect but otherwise I am seeing the same on my Cerbo (version 1).
Best is to follow the factory reset procedure documented clearly in the cerbo manual.
You will need to restore any custom settings on the gx.
OK thanks. Found it.
